turned on phone to META MODE screen
turned phone on and it says META MODE. i cant turn it off or press anything. anyone had this before or no how to fix it
It's like a halfway between the android bootloader mode and recovery mode, generally to fix it, you would hold the power button down for 10 seconds to force the phone to turn off and then hold the power button to restart the phone
このアンサーは役に立ちましたか?
This worked! Thanks a lot. I was panicking as it had never happened before. very useful
thank you it work
This won’t work for me, although that’s what it says to do on the phone
"Huntshu" Casual Gamer !
" Uyindoda ungabisoluka "-(isiXhosa)
South African : isiXhosa Translation
"Hurray"-as in Happy ! a celebration hauling to Casual Gamer- for advice.
" you are the man (Uyindoda)..... "ungab'soluka " ( this one is you home work search and know the Xhosa people ) Motherland emzansi
Had the same problem with my son's Mobicel phone. Just opened the back of his phone, took out the battery and switched it on again. It worked.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 41
過去 30 日: 182
今までの合計 44,812
8 件のコメント
what happens when you pull the battery?
Unlock Jocks さんによる
It depends on the phone, some ZTE's have a unibody with an encased battery, such as the ZTE Blade V0720 (The model I have)
The Casual Gamer さんによる
My power button does not work that is why i can't remove it from META mode.
- To use phone normally, press & hold Power button for 10 seconds to restart phone.
Help please. Can't find anywhere to get power button fixed.
iris vieira さんによる
Hi put on my mobicel r4 went on but only comes on to the vodacom add thingie and doesnt want to do anything trying to switch off for 10 seconds it goes off then put it on and does the same any help ?
zlecdelport さんによる
Thank you so much this is so helpful.
pssevume さんによる
3件以上のコメントを表示
