My motor stage broken?
it is saying that my motor stage is broken.....can you help
Not connected to one or all motors. Broken cable, connection not seated correctly, (Push Fit) and connection under arms damaged.
このアンサーは役に立ちましたか?
I have this issue.
Do I really have to go through the process of taking everything apart in order to fix this?
このアンサーは役に立ちましたか?
Is this un fix able? also the other thing is it wont turn off with the press of the button, I have to unplug battery to turn it off.
As @https://www.ifixit.com/User/3081968/Mich... pointed out this is one or more motor connection issues.
As per https://www.ifixit.com/User/3695100/swiv... from flight app view, we can find which motor is not connected as it’s red.
For me even though how hard I pushed the connector it did not work properly. The connector was loose. (even though I connected a different motor it did not detect by the motherboard.) I used my multimeter ohms scale which has around 1 Ohm per each of 3 pins. I removed the motor connector and sold it directly to the motherboard :). Did the trick for me and saved some money and time as well.
このアンサーは役に立ちましたか?
The motor turn just a little when I first turn on though but then goes to motor stage error
過去 24時間: 2
過去 7 日: 3
過去 30 日: 17
今までの合計 4,346
2 件のコメント
Same problem, though i suspect its the brushes in the motor( a piece that uses electricity to spin the motor and magnets). And my wire on the leg of the drone broke.
TL gaming さんによる
I have same problem but when I turn it on the perpellar acts like it wants to spin a sec then red-light comes on
James Smart さんによる
