メインコンテンツにスキップ
2017年8月に発表されたGalaxy Note8は、バッテリー騒動でリコールとなったGalaxy Note7の後継機種です。 Note 8は、2017年の9月に発売されました。
148回答 すべてを表示
I poked my top microphone hole with a sim ejector tool what damage?
So I acidentaly inserted my sim ejector tool into the top Mic hole - Could I have damaged the waterproofing or the Microphone itself? Is there any way to test the top microphone?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
13 件のコメント
It sounds fine I made phonemes afterwords
さんによる
vous etes bon pour faire changer l'écouteur. si il ne marche plus du tout servez vous d'un casque ou d'une enceinte bluetooth.
さんによる
Cool video... this answers the age old question, "I mistakenly poked the mic hole with the ejector tool, did I damage the mic?"... The answer is no... I'm sure all phone manufacturers thought of this... on pretty much every phone, the actual mic is off to the side internally...
https://youtu.be/85p_oFk595I
さんによる
I just got the s20+ and immediately poked that effin mic hole. Why is it near the sime hole -_-
さんによる
@Kitsune Ken, I did the same thing.. They are the same size and right at the top :-(
さんによる
8件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
Yes. You could have done quite a lot of damage. I doubt the "water proofing" is damaged, but you could have punctured the microphone. I would say, do a phone call, or just install a recording app on your phone then play it back. If you damaged it in any way, it will sound BAD or completely inaudible.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
The microphone is fine I made phone calls already only thing I'm worried is that the waterproofing damage
さんによる
I highly doubt it. most of the time that waterproofing is just a small mesh. It would have flexed with it. Nothing to worry about.
さんによる
Dont listen to Kevin I actually doubt hes been inside the note 8 because the top mic is not used as a normal mic it's used to cancel out noise and if you open a note or 9 the top mic and bottom mic is of at an angle so it's almost impossible to puncher it if you need proof watch the YouTube jerryrigeverything and his teardown he Shows you and explains that nothing happens.
さんによる
how do i fix it... i poked the mics on the bottom and their broken and i cant call or record anything because the mic doesnt work
さんによる
I accidentally poked my daughters mic hole on her tablet thinking it was where the sim goes. And how no one can hear her talk when she makes calls.
How can I fix it??
さんによる
コメントを追加
最も参考になった回答
Dont listen to anyone here the mic on top is off at an angle so it won't puncher the waterproofing nor the mic if you need proof watch the note 9 teardown on a YouTube channel called jerryrigeverything he explained that the mic and waterproofing is of at an angle so even if you stick it in it wont break or damage anything.
このアンサーは役に立ちましたか?
スコア 5
6 件のコメント:
Is it the same case with OnePlus 7
さんによる
Thank you for informing me. I believe you because millions make that mistake so the manufacturer probably designed the device to prevent damage in that area.
さんによる
I've just done exactly the same thing.
さんによる
same i did with my one plus nord.
さんによる
how about samsung a72? I accidentally poked it's top microphone with sim injector is the microphone and waterproofing still fine?
さんによる
1以上のコメントを表示
コメントを追加
Ask anybody that says yes that you damaged it, the mesh, or the rubber gasket, if they've actually had a phone apart and seen the sim popper/paper clip inserted and actually what it came in contact with. Most people that say something's damage has never seen the internals of the phone with this inaction.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
@flait111 thank you for indirectly helping. Your accidental poking of the microphone slot with the sim ejector tool helped me with my "muted" microphone problem. Apparently, it was being clogged by debris. Gently scooping 80%of it out w the sim ejector tool was more helpful than blowing into it as adviced by a lot of online note8 users, then following it up by gently brushing it w a soft bristle.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I also mistakenly poked a paperclip into the mic hole on top of my s21 and now voice type doesn't work. Bottom mic for phone calls works fine. Any suggestions for fixing this? Does my phone need surgery?
さんによる
コメントを追加
回答を追加する
Andrejs Paskins さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 66
過去 30 日: 288
今までの合計 55,388
