Temp gauge sometimes reads full scale
Mitsubishi Cedia 2002
Temp gauge intermittently runs to full scale but water not boiling?
Have heard there are 2 sensors on this model Can only find one at this stage
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
If the sensor you found has only 1 wire connected chances are that it is the temp gauge sensor. You could prove this by disconnecting the wire from the sensor and then connecting it to earth. Switch the ignition to ON and see if the temp gauge registers full scale.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 113
2 件のコメント
@hamster1 Mitsubishi Cedia 2002 as in the Japanese version of the Lancer? What engine size does it have etc.?
oldturkey03 さんによる
I believe it is 2L
Jim Dillon さんによる
