メインコンテンツにスキップ
2009年1月に発売されたオフィス用インクジェットプリンター。モデル番号はG510n。
39回答 すべてを表示
Broken gear tooth in scanner
Hello, I noticed that whenever I turn on my printer, it makes this very loud banging sound. I managed to narrow it down to a broken tooth on the rack the scanner light goes across, as shown in the picture. Is there a way to replace it or get it repaired? Also, this isn't the wireless model, but there is no device listing for the plain one.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I'm not sure about replacing the part, but the answer in this thread (Which glue will work best to repair plastic dome lid locking part?) has tips on repairing plastic things. It's easier in this case as it's not food-related, so the options to glue it are much more abundant.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for the reply! Not sure that that helps though since there isn't really anything left to glue back in place, it looks like the tooth just disintegrated over time or something, as it is the tooth that the light bar parks on.
さんによる
I see. You could rebuild it with the liquid plastic welding stuff. Otherwise, you might try some Sugru: https://sugru.com/ or [リンクされた製品が存在しない、もしくは無効: IF145-171].
Though I'm not sure how well Sugru would do on such a small thing.
さんによる
コメントを追加
回答を追加する
da stumer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 22
今までの合計 280
