How can I repair charger
How can I repair the charging female part on the Blu vivio 5r?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@bedanngugi difficulty with your off-brand phone is finding instructions on how to tear it down,.the charging port is soldered to a separate sub-board.
You would have to desolder it and replace it or replace subboard WBL7519 completely. The port is available at places like this
このアンサーは役に立ちましたか?
Ok when considering upgrading to a new phone which phones are built well but are also easy to repair
where can I buy this piece?
mario lopez do a search for the subboard WBL7519
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,009
3 件のコメント
What specifically is wrong with it? Not charging? Visibly broken and needs a new port?
Rachel Acosta さんによる
The charging port is moving and has to be in a slightly upward angle for the changing to take place so I was wondering what I can do to fix the issue
Bedan Ngugi さんによる
You need to fix the charging port or replace a new one. It needs a solder so you'd better send it to a repair shop.
Mandy さんによる
