メインコンテンツにスキップ
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
78回答 すべてを表示
Why does my graphing screen keep saying "error: invalid dimension"?
I drew a circle one time, after that my graphing screen doesn't work anymore. I rely on the graphing screen a lot to check my work so if it doesn't work it's a problem for me.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
for me is the same when I tried to graph an histogram, it says invalid dimension error and below 1Quit. How can I solve this?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi Clara,
The ERR:INVALID DIMENSION error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff.
You specified a list dimension as something other than an integer between 1 and 999.
You specified a matrix dimension as something other than an integer between 1 and 99.
You attempted to invert a matrix that is not square.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
回答を追加する
Clara Chen さん、ありがとうございました!
統計データ:
過去 24時間: 15
過去 7 日: 207
過去 30 日: 755
今までの合計 30,104
