メインコンテンツにスキップ
2017年3月に発売されたMoto G5 Plus(モデル番号XT1687)は12.0メガピクセルのリアカメラ、1920 x 1080解像度の5.2インチスクリーン、Android 7.0(Nougat)オペレーティングシステムが搭載されています。
Receiver not able to hear my voice
When I call someone I can hear them but they are not able to hear me. I have tried restarting my phone and also factory reset the phone but it didn't work
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
6 件のコメント
I called and I was not able to hear
さんによる
install voice access and say ok google, it works it worked on my moto e4 plus, try once, or try moto voice access from moto app options, thank you
さんによる
When I make a call by moto g31 the receiver of my call hearing disturbance in the background.same sim I used in other phone then no problem.what to do.any setting problem.please guide me to fix this issue.
さんによる
Same here I can't be heard when I make a call or I'm heard with interruptions which is to say people can't hear what I'm saying. Very frustrating.
さんによる
I just opened my google assistant and used it. Then I tried to make a call and it fixed the microphone! What in the world? No idea why that worked but it did!
さんによる
1以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
Hi @rehankhan123
Try using the earphones with the microphone attachment on a call and check that you can be heard properly.
If so then there is a problem with the phone's internal microphone or perhaps the voice inlet hole at the bottom of the phone is partially blocked with lint or dust.
Use a bright light and a magnifying glass to check that the voice inlet hole at the bottom of the phone is not blocked with lint or dust.
If it appears to be blocked DO NOT use a pin or probe to try and clear it as you might damage the microphone which is directly behind the hole.
Try a vacuum cleaner, using short sharp bursts to see if this clears the obstruction.
If it appears not to be blocked and it is OK when using the earphones with the microphone attachment then there may be a problem with the microphone itself.
If you cannot be heard properly when using the earphones with the microphone attachment either then there is a problem with the voice transmission circuitry in the phone.
このアンサーは役に立ちましたか?
スコア 7
コメントを追加
最も参考になった回答
Open phone settings>apps&permissions>app permissions>microphone>Google>turnoff microphone access to the Google and restart your mobile,after done my phone mic working on call
このアンサーは役に立ちましたか?
スコア 10
12 件のコメント:
I had one of my speakers cloged had to clean works good now
さんによる
Turned off microphone for Google and the mic was restored to phone calls. Definitely a bug in Google's software.
さんによる
Thanks. But how to do it. Please elaborate.
さんによる
this fix worked for me too
さんによる
this worked for me!! after hours of trying, this worked for me!
さんによる
7件以上のコメントを表示
コメントを追加
I have the moto e5 supra. During calls, the receiver would say they couldn’t hear me all of a sudden and it sounded like I was sitting on my phone (very muffled). I took my phone case off as I say nothing obstructing the microphone hole. I haven’t had a problem since. It really sucks not having a case on it for protection, but I’d rather the receiver be able to hear me.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
There has to be a case for your exact model which has the mic and other holes in the right places. Cheaper cases don't bother put holes and opening where they belong.
さんによる
コメントを追加
回答を追加する
Rehan Khan さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 21
過去 30 日: 130
今までの合計 90,914
