メインコンテンツにスキップ
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
554回答 すべてを表示
Will not move forward or reverse
Have a Craftsman ZT7000 zero turn riding mower. Used it two days ago, now it will not move forward or reverse. Starts great, blades engage, belts are tight, I am at a loss. The two "arms" feel very stiff when I push or pull on them.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
5 件のコメント
Have thus same problem several times a year with our Cub Cadet mower, I am at the point of paying people to NOT buy any mower with this feature!
さんによる
Holy Molly.....IT WORKED!!!!!!!!!
We can't THANK YOU enough....we couldn't figure out why the tractor would NOT MOVE at all. It was the easiest trick EVER!!!!
さんによる
We found out the bearing on the clutch shaft was shot replaced it problem solved
さんによる
My cub cadet will go in reverse but not forward. It's got a new transmission and when it's jacked up the forward works. I noticed that the pully and fans stop moving on the transmission when trying to go forward. I have checked everything that was listed.
さんによる
I don't see those levers on mine
さんによる
コメントを追加
3件の回答
ベストアンサー
@themailgirl you do want to check to make sure that the transmission releases may have been engaged. Those are the levers located at the back of the mower, just under the hitch, that need to be released so the mower can be moved without the engine running. They are basically two rods that sit side-by-side with loops on their ends for handholds and it is possible for them to catch on something and pull out, disengaging the transmissions. In that case, just lift the levers up and push them in.
Of course it is also possible that the rods have hit something underneath the unit and were damaged so that the transmissions are disengaged even with the levers pushed in. So check for any damage that may prevent the levers from moving. Even so you said that the belts are tight, you do want to make sure that your drive belt actually moves and does not slip or does not move at all.
Of course it could be the hydrostatic drive not having enough fluids etc, but for that I would need to know which drive this is. Craftsman usually use Hydrogear transaxles and trying to determine which one. See if you can take some pictures of your rear axle so we can try to identify it. Use this guide iFixitでの質問に画像を追加する方法 for that the top fan/pullet location etc. is usually a good identifier.
このアンサーは役に立ちましたか?
スコア 7
9 件のコメント:
Hello I have a craftsman hydrogear zero turn the right side is fine but the left side will not Ingage it make a noise like grinding but wont move can u possibly help me out pls
さんによる
This was very helpful. I just purchased a CRAFTSMAN T210 Turn Tight 18-HP Hydrostatic 42-in Riding Lawn Mower. it was delivered to the house. It started up perfect. PTO was engaging just fine. but it would not move forward or reverse. I was very confused . I did a search on the inter-webs and found this. went outside and sure enough, by me pushing that pin in the back, engaging the transmission, it then started to move forward and reverse just fine. I would have had no idea to try that. the guys from Lowes when unloading it pushed it over to my garage. He even started it to show me that it runs. but never went forward or reverse. And never showed me to look there. Just my luck that the small rod was pulled out. I had to push mine inward. It looked different then what you had shown above but I got the just of what it did. thank you for this troubleshooting.
さんによる
If it was pushed, that is an immediate sign that the pin is pushed out, as you can't push it with the transmission engaged.
さんによる
I have this problem, and have tried to push the lever in, but it seems to not make the connection. Even with it pushed in, it doesn't move. The forward-reverse pedal seems to not have any resistance. Any more suggestions? Do you reply with an email?
さんによる
I have a zero turn mower and the motor will crank and the blades will engage no problem. But the arms won't move the mower no matter how much I've tried. Any thoughts?
さんによる
4件以上のコメントを表示
コメントを追加
@oldturkey03 You are super helpful! We have the same exact problem. We checked your first suggestion and that doesn't work. We noticed this dangling underneath. Do you know what this connects to by chance?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@tammym47481 interesting......what make and model is your mower? Can you zoom out and post an image of where this part is located, in reference to your mower as a whole.?
さんによる
コメントを追加
My mower has no reverse or forward
The pin is pushed in
The drive belt looks good and moves
Now what?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
C. Shelton さん、ありがとうございました!
統計データ:
過去 24時間: 58
過去 7 日: 354
過去 30 日: 1,609
今までの合計 93,196
