HD has a fuzzy sound if turned up
I am having the same issue? My UE BOOM 2 is only around 6 months old? I have done a reset and still keeps cutting out HD has a fuzzy sound if turned up like the speaker has blown?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @kate12
Try using the aux input to see if it only a BT problem or whether it is a BT and a possible speaker hardware problem.
In any event even if it is only faulty when using BT as you have tried a reset which didn't work and given that you've only had it for 6 months I suggest that you consult the manufacturer's warranty information that came with the documentation for the speaker (or find it online) as to what you have to do to make a claim for a manufacturer's warranty repair, replacement or refund.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 5
過去 30 日: 6
今までの合計 6,039
