メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Why my iPhone won't boot?
my iphone 7 fell into the toilet and doesn't work anymore.
iphone boot up but it stuck on apple logo .
if i try to connect iphone to the computer in every ways, recovery mode, dfu mode, normally, computer doesn't recognize it.
please help me
thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Your phone was either damaged from falling on the hard porcelain or from getting infiltrated by water, possibly a bit of both. Even though the iPhone 7 is water resistant, it is still possible some water got inside. At this point the phone must be opened and cleaned properly asap.
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
If the phone still doesn't work, then a micro-soldering repair shop can properly troubleshoot your phone.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Emanuele Amantia さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 77
