Why is the solder different on my Xbox one elite controller?
I am trying to replace the thumb-stick module on my Xbox one elite controller, because it started to drift. But, the solder on the thumb-sticks is not the same kind of solder as the wires that connect the rumblers to the controller. The solder is much different and does not come off with my soldering iron. I need major help.
You need more heat . The part is in the ground plan of the circuit board. the ground plain is soaking up your heat and it will take longer to remove the solder. Try adding new solder to the old too .
Clayton Armagost さんによる
