error message in contacts, you have disabled a required permission
When u click on a contact is says you have disabled a required permission
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Most operating systems always want your apps to have permission to access any data on your phone.
In my specific phone and operating system (LG Stylo 3), to access the permission I just locate the apps list in settings, click on the menu button, select configure apps, and the first available setting is app permissions.
There you can turn on any permissions that your contacts app may need to run properly.
To avoid these problems in the future, it is wise to Allow services that apps request access to. As long as you trust the application at least.
このアンサーは役に立ちましたか?
This was a great help. Thanks so very much. No one else was able to tell me. Thanks again.
Worked. Thanks so much!
What do.i do if I.doñ:t tr
What do I.do.if I don't trust all my contacts
Thanks Daniel! Wow... That did the trick! You saved me from having to get a new phone!
Click home button at bottom so you are at the home screen.
Press the middle circle button with six dots in it. Just above the home button.
Press settings
Press apps
Drag your finger from middle to the top until you see contacts
Press contacts
Press permissions
Look at the upper right of the screen, you will see a set of 3 dots in a line.
Press the 3 dot icon
Press all permissions
Press home and try to open contacts again it should work
このアンサーは役に立ちましたか?
It did not work for me to press home at the end, I had to back all the way out for it to take effect. Otherwise this solved my issue though.
thank you-worked well.
it didn't seem to work, it keeps telling me something about a system overlay
Thank you this worked for me!!!!
It turned out to be my dialer app. It wouldn't even open. Apparently some how I turned off the location and it has to be on just for me to use it.
thanks, you helped my mom whos terrible at electronics. thanks dude.
Yes I want to be able to add contacts
このアンサーは役に立ちましたか?
The instructions given were followed by each step but I was still unsuccessful in removing the error message when I attempt to add contacts.
Awesome babara Falk me a,
Yes says disabled required permissions
このアンサーは役に立ちましたか?
Says enabled required permission
I don't know what app they are taking about
How can I add people if they say that
このアンサーは役に立ちましたか?
It says disabled premission want let me add to contacts
Yes it says enabled required permission
このアンサーは役に立ちましたか?
I also have that problem. I'm going to use the advised help in settings to get this permissions problem resolved.
I don't know how get my contact to this phone to work
このアンサーは役に立ちましたか?
I denied permission for my contacts to have access to my calendar now I need to correct that because I can't add names to my numbers
I did the exact same thing as Stephany Williams did . I am willing to give permission for the permissions I have denied . Please fix it . Thanks from , Ferlin Power .
このアンサーは役に立ちましたか?
None of the above worked for me so I found a way through the mess on my own. I went to notifications and the 3dots reset app. Now I can make phone call the goggle way.
このアンサーは役に立ちましたか?
If you would go to Setting; Apps;
Contacts. Make sure all permission is granted. That should resolve the issue!
このアンサーは役に立ちましたか?
How do I unusable a required permission o. My contacts I can't save any of my contacts ?
このアンサーは役に立ちましたか?
I want to save my contacts but it says I disabled a required permission how can I fit it to save my contacts on my ZTE straight talk phone?
Yes I can receive messages or send them it always said you have permission
このアンサーは役に立ちましたか?
.# hi
12345
このアンサーは役に立ちましたか?
Hope can I activate my contact list so I can add additional contacts
Go to settings / apps/ click on 3dots up top/ reset app permissions / this will reset permissions the when try to add contact / must click allow access
このアンサーは役に立ちましたか?
Yes!!! I stayed on phone with tech support for 40 minutes, for him to tell me to search on you tube, lol. I should have googled it to start with. Thanks so much!
[http://][http://]* Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. **)
このアンサーは役に立ちましたか?
I have this problem all the time and really need to know how to fix it so that I may see and delete contacts please help me ASAP with this problem thank
このアンサーは役に立ちましたか?
I want to erase some of my contact numbers. Thank you! Disable my permission code.
このアンサーは役に立ちましたか?
Thank you! Okay this was positive
Yes this is what I have done by mistake
I cannot get my contacts it says disabled required permission .can I reverse it?
このアンサーは役に立ちましたか?
I cannot get my contacts it says disabled required permission.i need to reverse this
Messaging says you have disabled required permission
このアンサーは役に立ちましたか?
I am unable to access my phone contacts and phone numbers I need to rectify this problem.How?
I have unable requirements
What to do?
このアンサーは役に立ちましたか?
I am disabled to some requirements.
What to do?
Thank you
Q mobile infinity contact number not save in mobile you have permission deny problim k se thek hoga?
このアンサーは役に立ちましたか?
Ah, this one is definitly on Android developers: there are various permisions, that is why is importent to WRITE WHAT IS THE PERMISION NAME IN PARTICULAR, in this case check storage(yes, storage permision). On my phone list of permisions: "call logs", "camera", "contacts", "phone", "sms" and !!!!!!!!!! STORAGE
このアンサーは役に立ちましたか?
過去 24時間: 7
過去 7 日: 68
過去 30 日: 248
今までの合計 144,970
I can't call because my phone is saying that I have disabled required permission please help
Jason Arndt さんによる
Jason Arndt I have the same problem, let me know if you have learned how to fix this and I'll do the same
Virginia Stewart
Virginia Stewart さんによる
Thank you this helped!!
Amber Glenn さんによる
Pls I have the same problem too pls help me
Timothy Aborah さんによる
Help I have the same problem I just bought the phone
vicky さんによる
11件以上のコメントを表示
