Truck Wont start, fuel pump shorted
1996 K1500
Found fuel pump shorted, changed full assembly. Wont start, ac wont work, doors unlock electric but wont lock, no bad fuses.
Is your new pump kicking on? Did you find out what caused the first pump to short out? If you look down the throttle body while it's cranking, is it spraying fuel?(carb press gas and accl pump should squirt a stream) if the fuel pump is not coming on then check the fuel pump relay underneath the hood on the firewall passenger side when the key is turned on listen for a click.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 216
Battery is fully charged. WAs disconnected for work.
Kevn Dixn さんによる
Let's start with the no starting issue. You replaced the pump assembly but does the fuel pump get any power? Where and how have you checked?
oldturkey03 さんによる
