メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
How to repair or replace the micro usb port
Ok so my Samsung Galaxy SIII stoped charging, I can get it to charge for a split second but the battery was fully drained so I cant start my phone up yet. it is quite hard to maneuver the micro usb to a valid conection and i am sure its bent beyond repair. I tried desoldering the micro usb but my soldering iron doesn't get hot enough (cheap hobby iron with no temp. control) how do I fix the port so I can use my phone again?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
well i believe you already started doing it yourself, if the solder contacts on the connector look like it has a solid connection to the circuit board then that shouldn't be the issue, and you should look at the contacts that the cable connects to, to see if anything in there looks out of place, if not then try cleaning the connections with isopropyl alcohol. You can use water but that will cause corrosion creating problems in the future if you can get to them, if cleaning doesn't work then i'm afraid that you will have to get a higher voltage or multi-voltage soldering iron and buy a replacement micro usb port .
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Todd Riley (Nathanyal100) さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 915
