Help on charging port repair
My speaker wont charge and i opened it up. Once open i saw a red wire that wad not attached to anything and i cant see where it must go. The inside of the charching port had a plastic inside that also fell out. Where should the wire go and should i replace the entire charging port or can i just put it back?
You can add a different charging port.... After all it will function the same thing
Lethabo さんによる
the red cable is the antenna bru
hicham bayed さんによる
How do I open the carry handle screws?
hamhead さんによる
I also cannot get the carry handle screw off , please can you assist
bradpearsall9 さんによる
How did you take off the 2 big handle screws on the Blaster? Cannot get the big ones off
bradpearsall9 さんによる
5件以上のコメントを表示
