メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
Changing the license plate light bulbs
I need to change the license plate light bulbs, however I cannot remove the plastic cover. It appears that I have to remove many other parts. The owners manual does not show how to do this.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
6件の回答
ベストアンサー
Open the Equinox's rear hatch. If you have an assistant who can hold the hatch in the half-open position, this task will be easier.
2
Remove the two screws from the lens cover of the lamp you need to replace, and remove the cover. The cover might be stuck to the rubber seal, requiring you to gently pry it off.
3
Pull the burned out bulb straight out of the socket, and replace it with a replacement bulb.
4
Replace the lens cover and insert the screws. Do not tighten the screws excessively or you may crack the cover
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The bulb slipped up in the door, how do you get it back?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
How far in the door did it go? You might use a wire to fish for it, otherwise you may have to remove the inside panel.
さんによる
コメントを追加
Carry it to AutoZone, buy the bulbs, and they'll install the for free.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
They will replace a license plate bulb for free?
さんによる
コメントを追加
This is the easiest method, a little tight working area but it can be done. Took it to Auto Zone, their answer was that I would have to take it to the dealership. Only way is to remove the interior cover and pull the bulbs out and then place it back inside. Said it would cost around $75. Took it to American Lube, guy did the above method and had them replaced in about 5 minutes. No charge but I gave him something for helping me out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
When you pull off the clear plastic lens you will probably tear the gasket. Make a new gasket with some gasket material and re-install. You can also use a thin coat of silicon.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Put a little black electrical tape on the bulb and leave a “tail” on it to grasp with needle pliers to push bulb in, then pull tape off.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
booz bat さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 31
今までの合計 21,009
