メインコンテンツにスキップ
A compact food processor with an internal bowl scraper first manufactured in 2012.
4回答 すべてを表示
Lid refuses to come off and when plugged in there is no sound
I got this as a gift 2 months ago. I set up the processor based on the instructions then plugged it in...the processor did not work at all.
Now I am trying to pull down the machine and the LID is stuck and will not move even though I have tried turning it both clockwise and anti-clockwise.
PLEASE HELP
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
Sometimes those bowls can be put on in the wrong position, in which case the safety switch will prevent it from operating. Check manual and compare the position of handle with your unit. If it doesn't match, that is the problem. Some extra force might be required to remove bowl that is put on in the wrong position.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It is not the BOWL that cannot be removed - it is the LID
さんによる
コメントを追加
回答を追加する
Shorna-Kaye Edwards さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 25
今までの合計 4,168
