メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
Should I replace the battery?
Hello there, I got a dead iPhone 7, so I tested the battery, and the only “weird” thing.. is that the battery is rated 3.8v… and on this one.. im having a reading of 4.1V…. maybe this overpowered issue is preventing the iPhone to turn on???
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
No, your battery is fine. A fully charged 3.8V battery will typically measure ~4.2V.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Ohhh nice.. so there's anything I can check of why the phone is not turning on??? or it seems to be the logicboard that its fried?
さんによる
You should give me more information on the history of the phone. what happened to it before it died, was it dropped, damaged, contact with water, repaired etc.
さんによる
Well my sister says... that it was dropped, but several months before she was using it normally, one night she plugged the phone... and next morning she noticed the phone was off... and since that morning... the phone is off =(
さんによる
There's a good possibility that the logic board suffered some damage, either physically or electronically. Sometimes the problem shows up right away, other times it only appears later on.
This type of problem requires a micro-soldering repair and is not a DIY fix.
さんによる
Oh I seee... thanks god I got a friend specialized in micro soldering on apple devices... but thanks for you super help =)
さんによる
コメントを追加
回答を追加する
jbermudez27 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 212
