2010 ford f150 radiator fan stays on
2010 Ford F150, Radiator fan seems to be running on high more than it should. Fan kicks on about 30 seconds after vehicle is started and is extremely loud. Even kicks on when its a cooler day. Also stays on when driving down the highway. Thought the fan was supposed to kick on when it reached a certain temperature then goes off once the temp drops. Switched out the high and low speed relays and did no good. I also noticed on the highway about a 30-40 minute drive the A/C was not blowing as cold as it should that I started sweating. Does blow cold when driving around town at low speeds or even just sitting there. Not sure if the continuously running fan and A/C not blowing as cold as it should are tied together.
この質問は役に立ちましたか?
26 件のコメント
2014 f-150 Sox 4x4 5.4 liter My fan seems to be running more frequently than normal and it is loud almost like truck is idling high but why now never have heard it since the truck was knew now at 72,000 miles it has started what is the diagnosis?
Dave62 さんによる
There is no resolution to this problem that i have seen here. I have a 2013 f-150 v-6 turbo charged. Temp can be not even to the normal or even just on start up and both fans running so loud and annoying. Seems to come and go. I did a water pump change and seems to have started after that work(not right away). Kept adding coolant to level as the air worked out of the system( MONTH or more!!) I had read in a blog that can be the problem. Still did it. Then it just stopped doing it. Now starting again. Seems to be associated with A/C system but do not know how. Anyone have any ideas??
james さんによる
My fan just came on when I got it worked on it stays on and it’s loud it’s never done it before what’s wrong
DeeAnn さんによる
For James above, we are having a very similar problem. 2013 5.0 v8, car went for last warranty service, they hooked it up to the computer and Ford’s latest update alters the temp the high speed fan cuts in to improve low speed AC performance. We live in Dubai so the thing runs constantly!!! Ford say they can’t change it back either.....We are stuck. It’s the wife’s car and she now wants to sell it!!
Simon King さんによる
DeeAnn above same goes for your problem, it’s the Ford software that has screwed your car.....
Simon King さんによる
21件以上のコメントを表示
