メインコンテンツにスキップ
M570 Wireless Trackball Mouse. Released in 2010.
11回答 すべてを表示
bearings that the trackball rides on?
has anyone replaced the bearings the trackball rides on?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
ベストアンサー
Usually they just need a good cleaning with a q-tip and some alcohol.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
the ball is sloppy loose, so that ball doesn't track smoothly
さんによる
sounds like the balls are in a retracted position.
さんによる
Wash ball with soap n water, dry thoroughly and rub some candle wax (birthday candle) on trackball. Replace ball and move ball in holder in different directions until ball moves freely.
さんによる
This was magic!! So so smooth now. I wish I had known this years ago as I love a trackball mouse.
さんによる
@dakblu You are the men
さんによる
1以上のコメントを表示
コメントを追加
There is excellent info on trackball bearing replacement in the comments of this:
https://sean-the-electrofreak.blogspot.c...
Which also refers to
https://translate.google.com/translate?s...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Soy candle wax worked!!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
UPDATE: Soy Wax got a little gunky; probably why the slick scroll didn’t last long. HOWEVER, one application of DRY OIL and the trackball is still smooth! This product is for hair and I’m sorry that I can’t recommend a more common alternative. Just in case you ever come across it: https://a.cl.ly/5zuBEBJO You only need like 3 drops
さんによる
Soy wax has a very low melting point. Paraffin and beeswax may be a better wax for it. I would try a little silicone spray and polish it off before replacing the ball - I plan on trying that myself. The silicone coating should also help to keep the ball a little cleaner.
さんによる
コメントを追加
Ohh my god!!! Wax works
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Eyeglass cleaner - the type with some kind of silicone whatever that fills in small scratches - leaves the ball and bearing-nubs almost too slippery. Sadly, wears off quickly, so flattened nubs will have to be replaced with something. Thinking maybe nylon screws, with ends filed or carved into points
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
james smith さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 70
今までの合計 5,715
