メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ガソリン式および電動ゴルフカートのサポートです。ゴルフカーや、ブランド名であるClub Carにちなんでクラブカーと呼ばれることもあります。
Doesn’t want to run unless choke is applied?
02 Yamaha G16A
Freshly overhauled engine. Now it may idle a bit but the quits, will not gain rpm unless choke is applied. Air filter, gas lines and carburetor are all new or cleaned. What else do I need to look at?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
i put a new carb and pump still wont run unless it is chocked
さんによる
コメントを追加
4件の回答
ベストアンサー
Dwight Coleman there are usually only a few possibilities if it only runs with the choke. One cause could be an air leak on the carb, head gasket, crankshaft seal. The other could be a clogged low speed and idle circuit. Since you just got the engine done I would double check the carburetor. You do want to make sure that it is set right and that it is clean. Check everything properly again and check for airleaks....
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Were is low speed idel circuit
さんによる
lol this guys knows nothing. Crank seal? Lol
さんによる
コメントを追加
最も参考になった回答
Dwight check for a leak around the base of the carb . Make sure the gasket seated properly and that its torqued down properly. Use a propane torch to check for vacuum leaks around the carb . Don't light it just turn on the gas and move it slowly around the seams of the carb with the motor running . When the motor speeds up you found your leak. Hope this helps
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
i have a chipper and it will start up but you cant chip with out the choke out a little bit, but if you put it under a good load it starts poping out the carbuator, can yall please help me.ive tried everything
さんによる
its out of time
さんによる
コメントを追加
You
1989 Evinrude 150 xp with muff on it idles ok a little sneezing. In the water it doesn’t want to idle when in gear . From idle to plane the boat will bog down unless I choke it once it planes it runs great. I have rebuilt the 3 carbs and made sure each passage was not restricted.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine goes ok untill i stop for a while, then wont go properly unless i push choke in and out a couple of times, then it takes off again
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dwight Coleman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 34
過去 30 日: 99
今までの合計 50,535
