The AUX doesn't work, the Jack Socket was broken
I have a Bose bluetooth speaker II, the hole of AUX was broken, how can I fix it.
Thank you very much!
@chunxia this sounds like the AUX has come off and been pushed in. this guidewill get you to the boards. then take a couple of good pictures and post those with your question. It will allow us to see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that. Most likely soldering a new connector to it should resolve the problem.
ガイド
難易度:
とても簡単
2 - 5 minutes
ガイド
難易度:
難しい
6 minutes
このアンサーは役に立ちましたか?
Hi, I have the same problem: is the AUX port definitely soldered on, or is there a way to fix this issue without soldering? Thanks, Lucas
過去 24時間: 2
過去 7 日: 4
過去 30 日: 5
今までの合計 959
