メインコンテンツにスキップ
Bose Soundlink II Speaker Replacement
必要な工具と部品
  1. Bose Soundlink II Speaker Replacement, Bose Soundlink II Cover Removal: 手順 1、 1の画像 1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Speaker Replacement: 手順 2、 1の画像 1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Speaker Replacement, Side Cover: 手順 3、 1の画像 1
    • Remove the black electrical tape in order to reveal the screws attaching the side cover to the main body of the speaker. These screws are on the base of the device.
  4. Bose Soundlink II Speaker Replacement: 手順 4、 1の画像 1
    • Using the T-10 star tip screwdriver, remove the two 13 mm screws located on the bottom of the speaker on each side of the battery pack.
  5. Bose Soundlink II Speaker Replacement: 手順 5、 3の画像 1 Bose Soundlink II Speaker Replacement: 手順 5、 3の画像 2 Bose Soundlink II Speaker Replacement: 手順 5、 3の画像 3
    • Slide the silver side cover down toward the base of the speaker. The silver cover will come off easily.
  6. Bose Soundlink II Speaker Replacement, Button Cover: 手順 6、 1の画像 1
    • Once the Bose Soundlink II Side Covers Removal has been completed, remove the two screws (13 mm) an inch below the buttons on the back of the speaker using the T-10 star tip screwdriver.
  7. Bose Soundlink II Speaker Replacement: 手順 7、 1の画像 1
    • Using a tool such as a spudger or plastic opening tool, insert the end into one of the small indentations located on the back of the speaker. Start either on the indentation farthest to the right or to the left.
    • Pry up with the spudger or plastic opening tool so that the cover is pushed up slightly.
  8. Bose Soundlink II Speaker Replacement: 手順 8、 1の画像 1
    • Repeat this process with each of the indentations, working your way left or right (depending on where you start).
  9. Bose Soundlink II Speaker Replacement: 手順 9、 1の画像 1
    • Pull the cover around the buttons off. If you’d like, you can remove the button cover as well.
  10. Bose Soundlink II Speaker Replacement, Speaker: 手順 10、 2の画像 1 Bose Soundlink II Speaker Replacement, Speaker: 手順 10、 2の画像 2
    • Pull the metal grill off of the speaker.
  11. Bose Soundlink II Speaker Replacement: 手順 11、 1の画像 1
    • Using the T-10 star tip screwdriver, unscrew the four 13 mm screws around each of the speakers.
  12. Bose Soundlink II Speaker Replacement: 手順 12、 1の画像 1
    • Lift off the cover. (You may need to pry it open)
  13. Bose Soundlink II Speaker Replacement: 手順 13、 2の画像 1 Bose Soundlink II Speaker Replacement: 手順 13、 2の画像 2
    • Unwind the wires corresponding to the speaker you want to remove (our photo shows the removal of the top right speaker).
  14. Bose Soundlink II Speaker Replacement: 手順 14、 1の画像 1
    • Carefully pop out the speaker after the wires have been unwound.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
John P Loughran
メンバー登録日: 03/02/17
472 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S3-G3, Harley Spring 2017 IUPUI, Team S3-G3, Harley Spring 2017人のメンバー
IUPUI-HARLEY-S17S3G3
4 メンバー
3のガイドは作成済み
3 件のコメント
Hello nice tutorial!
Does anyone know where can I find the #357158-0010 Speaker? thanks
zerocool500 - 返信
Does anyone know where to find the #357158-0010 SPEAKER ? Thanks
zerocool500 - 返信
Thank you ifixit I was able remove the broken aux pin by following these steps..
Ramkaran Rudravaram - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 58
今までの合計 7,084
