メインコンテンツにスキップ
Googleの自社名義で発売されたAndroidスマートフォンの修理ガイド、サポート、分解情報など。
1230回答 すべてを表示
How to remove wood deck nail out of metal holding board
Need to replace rotted wood deck board that has been screwed down with nail into metal bracing. Our deck is totally constructed of metal bracing. We have to remove nail from metal first. Using a battery operated screwdriver to pull nail up doesn't do it. Any other ideas or getting nail out of metal so we can remove rotted board to be replaced.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Try to get nail cutters and cut the nail and then hit the bord so the wood come out. You and also try to hit the metal so it bends, and then try to take the nail out. Sorry this is the best idea I could come up with
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you for this answer. I wish there was a way to post a photo. There isn't much of a way to cut the nail, since it is embedded into the wood, them metal. You can see the bottom of the nail underneath sticking out. I think it might work if you could saw the rotted board off as close to the nail as you can get, then try to cut the nail out somehow. The rotted wood is not so much a problem, as getting the nail out of the metal, so we can replace with new wood & screw nail.
さんによる
コメントを追加
回答を追加する
jacqueline さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 74
