Where to find replacement parts
How do I replace old parts on this older model camera?
Hannah Bynum you did not tell us which part. This manual 1.EPS should have all that you need to repair your camera.
このアンサーは役に立ちましたか?
It needs a new battery cover, off/on switch, and socket cover
Check for the numbers in the parts list in the SM. For example, the battery cover is part number CY1-1164-000 and available at places like this Not sure which socket cover you need but it might be part number CA4-1847-000 available at the same place.
tenho uma toda funcional , prisma com muito fungo e lente um pouco o restante toda ok . se interessar….
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 1,540
