メインコンテンツにスキップ
JBL Flip bluetooth speaker.Portable wireless speaker that is great when you are on the go. Released September 14, 2012 *Note not the JBL Flip 2
27回答 すべてを表示
Why my JBL Flip not charge EVEN AFTER battery replacement.
So recently my JBL Flip's battery reached 5 years old and it's not holding much capacity.
So I decided to replace it. But was not successful finding a correct battery. So i put it all back together. and attempted to charge it. Red light flashing and unable to charge. Help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Arthur Mixed I am somewhat confused by your question. you said you replaced the battery but could not find a correct one. Either you replaced it or you did not. If you did not, then it is your battery that is no longer working. If you did replace it then it could be your charging port. You will need a multimeter to measure it on the board while your speaker is plugged in and see if you get power to it.
Do not give up looking for a battery. A lot of times you can find substitutes at places like this. It may take a bit of browsing, but I am certain you'll find one.
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
Ok so the guy that i asked for the battery, he said it has to specially made. So i gave him my Original battery (which still works before) to make the new battery, now BOTH battery wont charge :/
さんによる
I just really want to know what does flashing red light while charging means.
さんによる
The red blinking light indicates an issues with either the battery or the charger. In short it is not charging.
さんによる
I have removed the battery and attempted to charge it. And the red light is still blinking, does it mean that it cannot detect a battery, or does it mean that the charger is faulty?
さんによる
I'd go with a bad battery first.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Arthur Mixed さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 4,396
