メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
Reattach volume button, it fell off
As the title says. The buttom fell off randomly, i released after a few seconds of it going and managed to locate it on the floor. Just the metal piece fell off, to look at the device it is black and feels like rubber, jut so you understand whats actually fallen off.
Can i reattach this? And is the device currently still water resistant (I think the rubber is the watertight gasket)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント:
this happened to me and all that fell out was the part that u touch and this black rubber with a little tiny stick thats also rubber
さんによる
コメントを追加
2件の回答
If you could post pictures we could probably give a clearer answer. But if it looks the way I think it will I don't think you'll be able to reattach it, even if you took the case apart. (Don't recommend doing this if you don't have to, very easy to break the back glass, plus it breaks the watertight seal.) If the button fell off he side I'm going to assume that the little bits of plastic/metal that hold it inside the case have broken off. If there are any little nubs sticking off either side of the button you could try inserting the button edge first and see if you can get it to pop back into place. Outside that you may be out of luck.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The button is completely smooth and doesn't have anything that would seem to hold it in place on it. The place i got it from said they'd charge me £35 for a repair, or may cover it under warranty as you can clearly see the device hasn't been dropped (no clear impact marks)
さんによる
Did you get this fixed or whats up?
さんによる
コメントを追加
Same happened to me and I had to download an app called Volume Control
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 37
今までの合計 13,510
