OL code showing .
When my Kenmore Model 110 washing machine goes to spin the OL code shows up and will not drain.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this would indicate either a drag on the drive system or the control board is failing. Be sure nothing is on the floor under the washer that could be causing a problem. Raise the lid & manually spin the basket, it should spin freely. If not, you may have an item stuck between the spin basket and the washer tub. If you unplug the washer and follow that procedure, you may find the cause of your problem.
I recommend scheduling for a technician to come out to diagnose and repair your washer.
Hope this helps
このアンサーは役に立ちましたか?
i suggest when you copy and paste an answer in from another source you read it completely
過去 24時間: 0
過去 7 日: 6
過去 30 日: 32
今までの合計 7,185
