メインコンテンツにスキップ
Released 2016, January, identified by model number K430T. The type of display is IPS LCD capacitive touchscreen, 16M colors and a 13-megapixel camera.
My screen is cracked and chipped at bottom.
I have an lg k10. I was at work and dropped my phone on floor. The screen is cracked in different spots and chipped off at bottom corner. Can I just replace screen or what do I need to fix this problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Assuming it is just the screen assembly that needs to be replaced you should be able to find a replacement part online readily. I would normally recommend getting the part on the plastic frame if available. They are relatively inexpensive phones and screens look to be in the $40 range, this device might be more inexpensive to replace. If that is the route you take please recycle the device.
How to disassemble LG K10?
http://www.ebay.com/itm/New-For-USA-5-3-...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
John lacy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 9
今までの合計 1,257
