メインコンテンツにスキップ
Asusによって製造されれたラップトップコンピューターの解体と修理情報です。
2523回答 すべてを表示
Keyboard displays numbers instead of letters
My daughter and I are switching laptops while she is in school. It's old and came with Windows 8 but now has Windows 10. We recently took it to our local Windows store to have her stuff taken off her ASUS so I would start fresh. Now when I try putting in my password, some keys display numbers instead of the letter. The "O" also has the number 6 on it and that 's what shows up. I thought maybe I had the caps on but no. Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
3件の回答
ベストアンサー
You need to turn off Number Lock on the keyboard.
To do this, at the top you will see a key marked "Num LK".
If simply pressing this doesn't turn off the number lock, locate the "FN" key, hold the "FN" key down, then press the "Num LK" key.
このアンサーは役に立ちましたか?
スコア 10
7 件のコメント:
Thanks, you save my day!!
さんによる
I am so grateful for the information, thank you!
さんによる
thank you sooooooo much.........you can't understand how worried i was about this problem ....... thank u very much for this solution........
さんによる
Thanks a lot, I was so worried. You just helped a lot
さんによる
Mine does not have a numlock button on it
さんによる
2件以上のコメントを表示
コメントを追加
Hi @bfloabbott, i think you had trigger the num lock on your laptop keyboard, or due to external keyboard num lock.
just turn it off and it should be good to go :)
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Bruh, thank you. I knew I had a numlock problem but it didn't occur to me that it was because I was using an external keyboard. Thanks so much.
さんによる
コメントを追加
On my asus laptop the numbers on the right side will not work on the tesco website. Ive tried so many things but still cannot resolve. I was goi g to send for repair but as they work on most sights than dont want to end up getting charged for it.
Can anyone advise me please?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 109
今までの合計 38,086
