メインコンテンツにスキップ
Samsung製のラップトップ用修理ガイド
346回答 すべてを表示
Laptop shuts down randomly
Hi, my R430 Samsung laptop randomly shuts down within 1 hr of booting up, even with very minimal usage. No blue screen. Power light is either red or red flashing with amber. Battery has been dead for a while so I just run it on power.
Is it most likely an adaptor problem, or a motherboard short circuit ? Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
@hubertwee there are a few possibilities and you want to check all of them. Sure it could be your AC adapter but I would also start considering replacing the battery as well as cleaning the fan and heatsink to make sure that your airflow is not blocked and your laptop shutting down because of higher temps. At this point it does not sound like it is a motherboard issue.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I am having a similar issue. Vents are clear, overheating not the issue. I did just have a power supply go bad on me. Replaced the power supply, no battery present at all.
Machine will power up and shut down within 15 minutes, faster if anything is plugged in(second monitor, USB HD, etc.). I'm thinking it's something in the charging circuit but since there is no battery present I can't think of what it would be.
Machine has operated on AC power only for 6 months + then all of a sudden it shut down and wouldn't power up until I replaced the power supply. Now it will power on for 15 minutes and then shut down.
さんによる
コメントを追加
Hi,
it might be a caused by overheating - are internal fan(s) are working ok and air vents aren't blocked.
In general, does laptop feels hot especially underneath?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hubert さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 38
今までの合計 6,926
