RPM varies while driving
While driving at 60 mph the engine rpm will jump up a couple hundred rpm then drop back down. It will do that constantly. What might be causing it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It could be your IAC (Intake Air Controller) that is stuck in the open position which could explain the RPM's jumping around. Try removing it and spray cleaning it and then reinstalling. Make sure however that it is moving freely after the cleaning otherwise the issue will still be present.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 8
今までの合計 1,635
1件のコメント
Hit the overdrive off button on the gear selector and drive. Does it still do it?
TCRS Circuit さんによる
