Noise Cancelling Shorting Out
When I slide the control to Noise Cancelling, headphone keeps shorting out and goes in and out between total noise cancel and regular sound. Any suggestions?
I found out that - as crazy as it may sound - in my case it had something to do with the battery brand I used.
I normally use Duracells, but always found them a bit hard to insert into the slot (it was really hard to close the lid with the battery inserted), but never had any issues until recently I bought a new pack.
Just for the sake of it I used a battery from a different brand - Varta in that case - and not only do these fit better: Noise cancellation works fine again! No more interruptions, problem solved!
Best regards, Ralph
このアンサーは役に立ちましたか?
Hi Erica, have you tried replacing the batteries and or connecting to another device?
このアンサーは役に立ちましたか?
I have a similar problem, but for me the problem is actually the button itself, just touching it triggers static and it keeps dropping the right channel regularly.
このアンサーは役に立ちましたか?
I have this problem too. I fixed it placing a small paper between the button (in "off position") and the headphone panel. It pushes the button a few mm inside the headphone and it appears to solve the problem. I think its a contact failure
what do you mean by between the button and the headphone panel?
A few close-up photos of this would really help!
過去 24時間: 1
過去 7 日: 10
過去 30 日: 56
今までの合計 3,754
1件のコメント
My power switch seems to not work. Van replacements be found?
madassteve さんによる
