メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Note 5は2015年8月に発売されたSamsung製のスタイラスペン付きファブレットスタイルのスマートフォンです。
*67 in text message?
I just happened to look at the contact number I was getting ready to text and saw that there was a *67 in front of the phone number. How did that happen? I didn't put it there. Does that mean the other person wasn't receiving my text messages?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Ok. First start with turning it off and on again. Then try a force restart
To force restart your device, press and hold the Volume down key and Power/Lock key on the device for 10–20 seconds. This performs a simulated battery disconnect
If that doesn't take, then you'll likely have to restore, which you'll want to backup your data
From a Home screen, tap Apps . These instructions apply to Standard mode only.
Tap Settings.
From the Personal section, tap Backup and reset.
Tap Back up my data to turn on or off .
Tap Backup account.
Tap the appropriate account.
Tap Automatic restore to turn on or off.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
I went to contacts and made the number the default number and the *67 went away. But HOW did it get there in the first place? So when I sent text msgs to this person, does this mean they didn't get them?
さんによる 共有
Probably not. You'll have to resend. The contacts thing was good to know. I'll keep that in mind
さんによる 共有
If anyone cares (*67) is Caller ID blocking. I have a feeling someone at some point got a hold of the phone and wanted to try to send texts without wanting the person on the other end knowing where it came from.
さんによる 共有
@avanteguarde cool to know! Thanks, bruv
さんによる 共有
My problem is a certain number automatically gets a *67 added Everytime I try to text it. I don't understand this.
さんによる 共有
2件以上のコメントを表示
コメントを追加
回答を追加する
Michelle Haith さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 2,301
