メインコンテンツにスキップ
The Ford Mustang is an American automobile manufactured by Ford that has been in production since 1964. It was originally based on the platform of the second generation North American Ford Falcon, a compact car.
65回答 すべてを表示
2006 Ford Mustang in limp mode
I have a 2006 Ford Mustang that is in limp mode. I took it to have the airbags replaced due to the recall. The service center replaced the airbags and also did another recall some kind of reset. There was 8 inches of snow on the road so I drove very slow home. The next time I drove it, I was driving 50mph and it lost power no lights came on and it will only go 25mph. WHY IS MY MUSTANG SICK?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
Hi Julie Marks,
If the throttle position switch (TPS) hasn't been replaced I would look into swapping it out with a new one.
さんによる
@blakeklein should've been an answer not a comment ;-) You know your stuff so answer with confidence and be a bit more descriptive :-))
Good to read your answers!
さんによる
The mustang does not move now,I cannot take it anywhere
さんによる
コメントを追加
2件の回答
If the check engine light is on can you post the code retrieved by a OBDII scanner?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
@tcrs_circuit Tim whenever you are trying to elicit more information from the OP make those a comment.
さんによる
@oldturkey03 OK will do! Thanks for the heads up!
さんによる
@tcrs_circuit This is what I was talking to you about: http://ocmensa.org
さんによる
Thanks @mayer . I am going to look into it.
さんによる
コメントを追加
julie marks since we do not know what was replaced, this is a difficult one to answer. I suggest you get it hooked up to a scan tool (Autozone etc. does it for free) and see if it comes up with a "throttle/pedal position sensor" issue. this would be the most common cause for limp mode on your year. Disconnect the battery for a while then reconnect and see if this clears the issue. If it does not or it returns think about replacing the TPS (throttle position sensor) which causes an awful lot of Mustang owners grief. It is not a difficult repair. The TPS is on the side of the throttle body and all you need to do is to If you can take out 2 screws and put them back in with the new sensor
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The only thing they replaced was the airbags because of the recall they also said they did a reset on the computer but they did not go into detail I guess because I'm a blonde woman they didn't think I would understand
さんによる
I hear you. Try to disconnect your battery and see if that resets. The limp mode may just be coincidental with the repair.
さんによる
コメントを追加
回答を追加する
julie marks さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 8
今までの合計 1,284
