メインコンテンツにスキップ
2.26 or 2.4 GHz / White plastic unibody enclosure
645回答 すべてを表示
Running more than two hard drive partitions
Has anyone had any success running more than two partitions on a single hard drive?
I would ideally like to run the latest Mac OS software but also have a partition to run Mac OSX Snow Leopard to use legacy Power PC applications and also run a third partition with BootCamp to run Windows 7.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Yes, I've run older MacBook Pro i5 64-bit 15" with 10.5, 10.6, 10.7, and 10.8 on the same time (quad boot). Note that OS X has a hidden partition or two. What I did was install one OS first, then create a DMG of it using DiskUtility and move it to a USB hard drive. I did this for each version of OS X, then I repartition the hard drive in to 4 partitions. I then use DiskUtility to restore each DMG to a partition of its own. When you then first turn on the Mac, hold down "Option", and it will let you choose the bootable OSs. You can go to System Preferences --> Start Up Disks to choose which one starts by default. Note 10.5 and 10.6 run only older hardware and you need to install their latest combo updates for drivers.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Caleb さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 64
