メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Changing my iPhone's motherboard
I've been using this iphone for quite a long time.Then it started too make problems.I brought it to a phone shop and they said i got to change my iphone's motherboard.What will happen if i change it?I really need help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Is your phone turning on?
If yes, do a backup of your data via iTunes or other backup software so you can restore it to the new motherboard
If no, you will lose all your data, this is the worst it can happen
The motherboard is the most important component in your iPhone so the most expensive
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Not now :( @soros So,if i change my motherboard all my data including my icloud will be lost?Its like a new iphone isn't?
さんによる
コメントを追加
It is rare that you come by a motherboard that "IS NOT" repairable. There are several Iphones I have received that the customer was told this (even though it's possible).
First, you should explain your issues in as much detail as possible to help experienced techs troubleshoot your problems.
Second, to replace your Logic Board, is replacing your phone (It is your phone). If it comes to that, you are better served finding a good deal on another phone and replace that way, then you could sell yours to offset the price.
Here on IFIXIT, you can find several experienced techs that can do a repair to most anything that offer mail in services and even no charge in some cases where it is not repairable. Of course you would probably prefer a local shop if available and you have done your homework to make sure they are reputable and good at what they do... but you are here now after going to a shop which tells me they are good and correct, it is not repairable...or they are not.
Please update your question to include all of your symptoms and history of the phone.
Best of luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Hazim Izz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 2,726
