メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
Wifi not working and fana going very fast. I've tried almost eveything
Hello, I am dealing with very strange issues. My macbook started to behave in very strange way. It all began at the day I have took it from repair. There was flex cable changed and mainboard lighting chip replaced.
That day, last friday it started to have strange lags which were only on battery, not during charging. I deleted only a .plist file and it worked fine for few hours.
After few hours it started to drop wifi and fans were going so hard (over 6000 rpm)
Wifi works fine only after boot, for about 20 minutes and ther there is no connection. Wifi is on but system info is telling me that it is off. I don't really know what to do now. I am really confused because of that situation. Before it was everything working well.
Thank you in advance
Maciek
Update (09/11/2017)
Wifi Problem
There is WiFi on but if I check system report it shows that WiFi is off. I can't guess what is happening here, and it makes me so nervous, just because I can't work online what is quite important to me.
There is also another problem
When I run geekbench it showed me that showed me
~1500 pts single core
~1504 pts multi core
The first one is normal, but second should be around 2100 as I got while I was running it before giving it to repair after short circuit
Update (09/11/2017)
Reinstalling system did not change anything. The problem returns
Reseting SMC and PRAM also doesn't work
I also written a message on facebook to the place where they repaired my mac
Update (09/14/2017)
Problem solved!!!
I mounted a disk caddy instead super drive and my macbook started to work as before. I have faulty hdd connector. I realised that voltage on battery is to low so at certain moment system was going crazy in order to avoid short curcuit. Now everything works fine!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I brought it back to the service provider. I have to wait few days now. They accepted to check it because they did not detect that something is still working not properly
さんによる
Problem solved. Faulty disk connector
さんによる
コメントを追加
2件の回答
最も参考になった回答
Take it back to the repair place. Issues like what you're describing are common when the technician forgets to apply new thermal paste, or applies new thermal paste very sloppily, during motherboard service -- which you have had. The fans are going full blast because you have overheating components on the motherboard.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Okay. I looked at the paste yesterday and I saw that the processor is not covered with paste and most of it is around cpu and gpu. When I checked temperature it was showing
CPU diode - 81 deegrees Celsius
And 50 - cpu
I placed a paste on it and it was not running well. Today fans started to work very intensively while launching the computer. And wifi is still dropping after short time
さんによる
Best to leave it as is and return it to the repairer as Steve has said. They have charged you for a service and it is not working; a reputable repairer will offer a warranty and it's not your problem to find a solution to this yourself.
さんによる
コメントを追加
81 C is perfectly normal. What chip did they replace? The ISL or anything to do with charging can cause this. Could you call the repair place and get us the component number they replaced?
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
There was screen backlight chip replaced.
さんによる
Backlight driver? What was the history on this? Liquid damage?
さんによる
there was a short circuit on the board. They said that they repaired it. It was going fine for 5 hours and then it began lagging. That was repaired after connecting to the charger. After that I removed .plist file Macbookpro7,1 according to the tips found on the internet. After reinstalling system on the same SSD disk it appeared again, but with symptoms like fan going full blast (6200 rpm, even 6300) and still drops the wifi. Flex cables are in good condition and airport is working but it becomes disabled
さんによる
Sorry for mistake, yes, backlight chip.
False friend word from Polish ;)
さんによる
It sounds like a sensor issues somewhere on the board. I'd bring it back and have them check it. See what they say as this issue can be caused by a ton of things.
さんによる
コメントを追加
回答を追加する
Maciek Welk さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 98
