メインコンテンツにスキップ
Repair and device guides for the 2016 Samsung Galaxy J5 smartphone, model SM-J510FN.
74回答 すべてを表示
Detection of a component on motherboard
Hello.
Can anyone help me with detection of marked component from J5 Duos motherboard?
Looks like somethink wrong has happend..
https://ibb.co/edYuWv
Thanks.
Update (09/11/2017)
Oh, thanks :-).
Phone was probably water damaged. I can see probably salt at two places on top of the borad. One image is from components around WiFi/BT and other image is different side of board - bellow front flash diode.
https://ibb.co/fL3ota
https://ibb.co/nAm8ta
So, phone is KO. Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
5 件のコメント
I think you need to provide some background information. Is the phone water damaged? Does it turn on? Any serious drops?
さんによる
is that not a soldered shield over the top
さんによる
It is soldered. But what is under?
And can malfunction of this component be reason for no-functional phone?
さんによる
I need j5 (2016) Board
さんによる
コメントを追加
1 件の回答
ベストアンサー
@fbituco you'll find your BT/WiFi under that EMI shield. Could be a reason for non-functional if your BT or WiFi is not working. You'll have to give us a bit more information about what is not working on your phone.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Fbi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 1,531
