メインコンテンツにスキップ
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202回答 すべてを表示
My phone won't turn on.
My phone was low battery (8%) before I went into work and after few time it become turned off and I tried to turn on my phone. I've had it plugged on the charger, my phone felt cold so I assumed it might be too low of a temperature or something and it's been over an hour of the same response whenever I try to power up.
Did my battery damage or something? It hasn't happened before.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I don't know about this phone in particular, but my phone was run over 3 times and the logic board didn't get damaged, so I don't think that would occur with your phone (don't quote me on this though). If it is an old phone, it could be the battery just finally gave out as they do. If you're curious, here is what causes them do give out eventually:
http://batteryuniversity.com/learn/artic...
My best advice would be to take a look at this teardown, but note that it has a repair ability score of 2/10, which is unfortunate. You can also take a look at the battery replacement as well.
HTC One (M8) Teardown
HTC One M8 Battery Replacement
HTC One M8の画像
ガイド
難易度:
中レベル
HTC One M8 Batteryの画像
ガイド
難易度:
中レベル
35 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ahmed masiul alam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 205
