メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
20回答 すべてを表示
Cost of fixing the touchbar
There is a crack on the touchbar of my macbook pro 15 inch. The touch is partially functional until the crack. Would like to know the price for repair and IF apple care will cover it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
7件の回答
最も参考になった回答
That is not going to be cheap, you basically have to replace the whole main case, with keyboard, battery and perhaps the trackpad.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My keyboard was jam by something, the Apple Store change the whole top case(include Keyboard, Touch Bar, Touch Pad, Top Metal case and battery). It cost me $575.13 in Seoul, Korea.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Wow! Really makes you wish that was a more repairable part.
さんによる
コメントを追加
I’m going to fix touchbar of my macbook pro. Currently, my cost is $60 for touchbar and $60 for toolkit from Ifixit. shipping and tax around $20. Total around $140. Let’s see i can fix it. I will try to record my repairing process.
BTW, where can i buy screws for Macbook pro 15”inch (2017)?
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Finally, i replaced my touchbar. screen comes out but touching sensor is not working. I think it is factory defect. I need to contact to IFIXIT. Before my old one was working fine touch sensor but display was not showing.
[image|1844024]
さんによる
Yes. I changed and it works perfect.
さんによる
コメントを追加
My laptop, which is same as yours, was soaked and the touch bar was damaged too. I went to the apple store and was told that if I want to fix the touch bar, I have to change the whole keyboard.....
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My touchbar's cover SOMEHOW popped up and it stopped showing the icons. Took it to the apple store and got told that it costs $750 ($100 labor included) to fix it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You cannot fix it as the whole logic board will be replaced and it can cost you around $1200-$1500
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Possible to fix but not an easy task to do.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nihal Wats さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 29
今までの合計 22,845
