メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
Can an SE be moved into a 5s housing?
I'm wondering if i can transfer all of my SE components into a custom 5s housing. I've looked around quite for other people that have asked the question, and it usually no since the iPhone SE logic board is supposedly slightly bigger.
However i've seen cases where people say theyve put an iPhone SE into a 5s housing shell anyway. Furthermore online there are 5s/SE custom housings, even though they aren't interchangeable?
I've looked at a lot of pictures online of the housings and i cant find any real differences. I might just dismantle my personal 5s and SE to see for myself.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
1 件の回答
最も参考になった回答
No, the internal size and screw holes are different.
このアンサーは役に立ちましたか?
スコア 4
8 件のコメント:
how do people supposedly do it anyway?
さんによる
I've no idea. The camera and flash are different between the two models.
さんによる
i just did it anyway. Flash wasnt really any different and camera fit anyway
さんによる
Awesome! You should add a guide here on how to do it.
さんによる
How do i do that? There wasn't really any difference except i kinda had to squash the nfc anetnna above the camera since there wasnt a slot for it. Other than that it was exactly like a 5s. The motherboard is technically slightly bigger, but the screw holes are the same.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Bob Mcroy さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 21
今までの合計 5,322
