メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Major curtains after Touch IC replacement
Hi community. I posted on here the othwr day about issues when replacing a touch IC then losing the whole phone to shorts.
I thought i would post up what has happened after nearly all repairs i have dome to see if anyone else has had the same problem and may know what it is. I have never got a new batch of chips (due to trying to find a new supplier and buying 'new' but never getting new) so its always my first suspect, but has anyone else had this problwm and it ended up being something else??
(No its not the screen being the issue)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
ベストアンサー
So i put another chip on this morning, put the screen on again and there was less curtains.
The screen was fine prior to the repair, but when i tested it on another device it had the same pattern. Put a new screen on and it was crystal clear and had touch back :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
I use microsolderingsupply.com haven't had any issues
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have never seen a touch ic complication that was due to a bad chip. Take off meson and see if you have normal display. This is almost certainly a technique problem.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Slammed by my idol lol and even after my flex donation!! Haha
The chips they sent me were all reballed. Some where missing balls and had chips out of thr side.
I will try again tomorrow and see how i go
さんによる
コメントを追加
I've had that issue with Meson IC purchased from Mengtor
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Are you jumping pad m1 from the via?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jacob Harvey さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 152
