メインコンテンツにスキップ
Final generation of the North American Volvo 200 series.
5回答 すべてを表示
replacing fuel filter on a 1986 volvo wagon
I need to replace the fuel filter on an 86 volvo wagon but can't get the rear fitting loose. Is there a secret to this?
1986-1993 Volvo 240 Repair
I need to replace the fuel filter on an 86 volvo wagon but can't get the rear fitting on the existing filter loose/ Is there a secret to this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
No secret, just use good tight fitting wrenches as you certainly don’t want to strip the hexes off the banjo bolts or the filter inlet/outlet. Sometimes it helps to set up your wrenches on the filter and bolt so that you can squeeze the handles together with one hand (like a pair of pliers) and rap on the bolt head with a small hammer - sometimes the shock wave helps the bolt break free. If you already got the front line disconnected, you may be able to get a better hold on the filter by applying a six-point socket to the front of the filter. In extreme cases you can even hold the banjo bolt (let its wrench wedge up against the bottom of the car) and turn the filter with a big long wrench or breaker bar.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I removed mine by using an air impact wrench on the banjo bolt -- came right off. Gas will spray all over, so I used a face shield.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lauren Sargent さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 219
