メインコンテンツにスキップ
Asusによって製造されれたラップトップコンピューターの解体と修理情報です。
2523回答 すべてを表示
Why do I have to choose between Windows or HL-DT-ST DVDRAM at boot?
Hi all,
When I first got my ASUS laptop, it immediately went into Windows 7 after turning it on. For a while now, though, I have to choose from a list of options before it will run Windows 7. The options are:
P0: Windows boot manager
P2: HL-DT-ST DVDRAM GT51N
Set up
I recently had my computer wiped and Windows 7 reinstalled (because of other issues), but this issue didn't go away. Is there anything I can do so that I don't have to select Windows boot manager every time I turn on my computer?
Note: I have already gone to msconfig and looked at the "Boot" tab. The only option there is Windows 7, the "Set as default" button is grayed out, and turning down the time delay doesn't help.
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
Do you have a bootable DVD forgotten somewhere in the drive?
さんによる
You mean a physical DVD? No, it's empty.
さんによる
Are you familiar with taking devices apart? It would be interesting to see if the problem stops occuring if you disconnect the DVD-drive from the motherboard.
さんによる
I would have no idea how to do that, but maybe I can look up some videos if it comes to that. I'd prefer not actually having to take anything apart, though, if it can be helped...
さんによる
コメントを追加
1 件の回答
最も参考になった回答
It could be the BIOS setting.
Maby during wiping the system a technician has enabled the option to stop and ask for boot options every time.
One could probably disable this setting in BIOS.
Go to Set-Up, which probably will enter the BIOS and look around for "Boot menu" or "Boot options" or something. Do not change anything that sounds dangerous though ;-)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Tried this, too, couldn't find a way to set it... it looks like it should boot with windows automatically, unless I missed something. Thanks for the suggestion!
さんによる
コメントを追加
回答を追加する
Allie さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 43
今までの合計 6,775
