メインコンテンツにスキップ
2014年に発売された7インチLDカラータッチスクリーンディスプレイを搭載したAmazonタブレットの修理情報です。
20回答 すべてを表示
Where can I find the IMEI or MEID number
I have an Amazon Fire HD 7 (4th GEN) tablet and I cannot locate either of these 2 numbers. Specifically, I'm wanting to use my fire to accept square payments but the more research I do the more I'm learning this may not be possible.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
You find the cereal number by going into settings under device find device options and click on it your serial number will be at the bottom hope this helps
さんによる
コメントを追加
3件の回答
ベストアンサー
  1. To view the SIM, IMEI, and Serial Number, from any screen, swipe down from the notification bar.
  2. Tap Wireless.
  3. Tap Mobile Network.
  4. Tap Advanced Network Settings.
  5. IMEI and SIM Serial Number will be displayed.
  6. To view the device Serial Number, from any screen, swipe down from the notification bar.
  7. Tap Settings.
  8. Tap Device Options.
  9. The device Serial Number will be displayed.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks for your response. I actually have to tap on settings on my noifications bar and then I am able to tap on Wireless. When I tap wireless I only have 4 options:
Wi-Fi
Bluetooth
Location-Based Services
Airplane Mode
Is my tablet missing information? Should I do a reset to factory defaults? I don't want to have to do this but will if I thought it would fix this issue.
さんによる
Is there a "More" area you can tap on? If so, try that to be taken into your Settings then located and tap on "Wireless & Networks"
さんによる
コメントを追加
Simply type code *#06#
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Type it where, if the tablet is your only working device?? I also am with Brenda Smith. Mine only have the same options.
さんによる
On dial pad of iPhone brother.
さんによる
コメントを追加
You can find your serial number by going into settings under device click on device options and scroll down to the bottom your serial number will be there hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brenda Smith さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 21,081
