メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone 5s Touch id inaccurate
Goodday Ifixit im having a problem with my 5s touch id it works i mean
.When im registering my touch id (Im having hard time fingerprint cant be read etc .)
But i can finish getting it when im using it already its having inaccurate like its says try again always how can i fix this ?
How can i fix this fingerprint inaccourate some times it do but almost all the time its no .
Is this just because the homebutton not place properly ?Or nah ?
Take note i have Tempered glass installed but i dont think it can stop the fingerprint sensor etc
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
If you've recently repaired your iPhone it could be that you've damaged the Touch ID cable. On the iPhone 5s and SE this cable is tricky to maneuver and disconnect without tearing and, if you do, you lose Touch ID Functionality.
A couple thoughts that might help you out:
  1. Try removing the Tempered Glass Screen Protector and setting up Touch ID from Settings > Touch ID & Passcode. Add your Left and Right Thumb and whatever your dominant hand pointer finger is. Then "train" the device to better recognize those fingerprints by holding those fingers over the sensor on that initial "Touch ID & Passcode" screen. You'll notice under "Fingerprints" that the corresponding finger highlights in grey for a brief second each time. This is helping the iPhone better account for the variations in your fingerprint.
  2. Make sure your screen is clean. Take a microfiber cloth and some screen cleaning solution (or rubbing alcohol, if you don't have any lying around) and clean the entirety of the screen. Additionally, make sure your fingers are clean.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Sir its says dont move my finger between scans even though im not moving it is it possible that its because of the tempered glass ,
さんによる
That would be my guess. Lay the phone down on a table or desk and don't move it, then try repeating. If it still causes the issue try removing the tempered glass.
さんによる
コメントを追加
回答を追加する
Fixie さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 313
