My screen cracked it is doing ghost touch
my xiaomi redmi note 2 the screen is cracked so is doing ghost touch which mean it control it self just keep clicking anything
@mofokeng as you already identified, your broken screen is responsible for the "ghost touch". Replacing the screen will fix this issue. This video should help you with that.
このアンサーは役に立ちましたか?
There are pins inside the phone that control the screen LCD. If these pins are moved from their original spot they will cause the phone to activate ghost touch, causing the phone to switch tabs and/or click on things. Try getting the inside fixed or replace the screen, as this is most commonly seen when cracked too much or greasy hands.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 7
過去 30 日: 22
今までの合計 7,290
