How to reconnect a controller to the wii
My Wii remote is not syncing to the Wii and I think it might be broken.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@jbeckwith try to sync it to your console:"
Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the Wii console. When the Player LED blinking stops and stays lit, the syncing is complete."
このアンサーは役に立ちましたか?
I tried that
You unplugged your Wii for a while to see if it resets? After that try to sync again or you could try this. Connect by pressing the red button on your Wii remote. It should start flashing for about 30 secs or so. Then, while its flashing, press the red button on your Wii console, open the flap under the reset button to find it. once you have done that continuously press 1 and 2 at THE SAME TIME 10 times then press power button on top left of remote, press the A button and that could make it work.If nothing else contact @tronicsfix and see if he knows of some common errors.
What happens when i put the red button on the back of the wii controller and it does not flash blue how do i connect it
Its still not working
このアンサーは役に立ちましたか?
Followed the instructions as told but still after many tries the screen pulls up saying it has lost connection and to hold 1 and 2 on the remote simultaneously to connect.
I even unplugged totally everything for awhile and the same message appeared on the screen.
I haven’t tried yet i will try with my remote that is not working. Thanks a lot for the infrmation
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 33
過去 30 日: 116
今までの合計 37,512
1件のコメント
My wiimote just blinks slowly ten times. That's all it does. It started a week ago when I was going to play and the remote just slowly blinked ten times. It did not just connect like usual or blink fast as usual. It's very strange and cannot find a thing about it anywhere.
Tony さんによる
